Garbage_Mechan
Garbage Mechanic
My son and I are going to help out a good friend who is currently disabled and can't work or do his own repairs.
He has a 94 F250 factory turbo truck that has fallen to the block worm. Needs a rebuild or another engine. Has the E4OD trans.
He also has an 84 F250 that has been in the family for a long time that runs good, low miles but the truck isn't usable. It has the C6 trans.
The plan is to swap the 6.9 into the 94, none of which worries me in the least, except that I'm not 100% clear on the flex plate / flywheel.
Using search I haven't found many references to this. My understanding is that the 7.3 flywheel shouldn't be run on the 6.9.
Does the 6.9 and E4OD share the same flexplate pattern? Can the 6.9 with it's current C6 flywheel and flex plate set up just bolt up to the E4OD?
Thanks
Thanks
