Maybe.
Could be asking about the air bleeder hole?
Sorry. I thought the high idle temp sender was supposed to be in the spot where the square plug is.Where?
Sent from my Nexus 6 using Tapatalk
Yeah. It was a quick pic as I was leaving for the dentist.You know, a finger or something pointing to the spot you are talking about or a circle made in paint does wonders.....![]()
The two prong is for the temp sensor for cold high idle and timing advance.
Sent from my iPad using Tapatalk
Isn't there supposed to be a temp sensor there?
Where could I order such a beast?You must be registered for see images attach
I've found it on Amazon for $52. Damn expensive for a simple switch. I might just wire a switch in the cab.You can get them online. Around $70ish.
