Looking at a truck. Opinions?
jeepj667
SL,UT
You know, a finger or something pointing to the spot you are talking about or a circle made in paint does wonders..... ;Poke
Yeah. It was a quick pic as I was leaving for the dentist.
Sent from my Nexus 6 using Tapatalk
jeepj667
SL,UT
Pointing at the plug.
Two terminal plug that wasn't plugged in to anything. Right by the threaded plug
Two single terminal plugs farther up the harness, maybe fuel heater?
nolson
Modesto, ca
The two prong is for the temp sensor for cold high idle and timing advance.
Sent from my iPad using Tapatalk
jeepj667
SL,UT
You can get them online. Around $70ish.
I've found it on Amazon for $52. Damn expensive for a simple switch. I might just wire a switch in the cab.
jeepj667
SL,UT
Decided I'm going to hit the tear-a-part tomorrow, I know they have a diesel there, and pull the switch. If it doesn't work I'll wire it to the cab.
jeepj667
SL,UT
So, I got a switch from the junkyard. I tested it on my stove and it worked. I got the new water pump and thermostat installed. I got the glow plugs solenoid wired correctly.
Now I found the olive at the end of the return line is shot. Is there any way to replace that line to get rid of the olive? I bought the filter to IP line from Conestoga.
I finally got a tracking number from R&D for the pump and injectors. Should be here Wednesday.
Studebaker62
