smcg89
Hey guys my first post here. Been lurking for a bit but cannot find a good answer anywhere online. Has anyone ever rebuild the leaf spring packs for front dana 60? I'm doing d60 high pinion kingpin swap into my 89 f250. I'm replacing the bushings with energy suspension and thats no problem. I would like to break the leafs apart and put new hardware and paint on them. The leafs had white nylon type pads between the pack and the mounting plates. Can I or should I replace these? are they for noise reduction or to stop from corroding together? Also, what to use for anti squeak pads if anything? fairly new to full size trucks so leaf springs are new to me as are diesels. Got this as a learning project hopefully to be long term daily driver when its done. I guess this is kind of an introduction along with my first questions. Yes I am using the original leafs from the 1 ton not the 250 leafs. Any insight is appreciated. Pics to see where I'm at.
