justinray
Contributor
Justinray, what caused your cooler line failure, do you know?
Overloaded the truck, I had a 94 f250 with a 351, pulled a CC '82 Chevy 6.2 4X4 home from Arkansas.
11 means she cleared KOEO self-test fine.
Are you sure next code is a 1? Should be a 10, and that's not really a code, but a separator between different types of codes, in this case between KOEO and continuous memory.
Then 14 is cause of your faulty tach sensor, for 29 you wanna follow Trackspeeder's advice and pull the VSS from the rear axle and see if it's got metal buildup on it, and finally 62 is your slip code that doesn't really tell you anything you don't already know.
As for you pet, it's a cutie, but I think I can one-up you on it:
