Christian9112
So I just finished all the mods and upgrades on my truck. I did a shake down and it is knocking after 30 min of driving. The knocking only happens right before the transmission shifts. It gets louder and louder and disappears after the shift.
The mods:
Turned up the IP 1 flat. (pump was advanced by ear. As throttle/rpm goes up, the advance just crosses the
line and starts the knocking? could lower inlet psi cause this?)
Oil temp sensor on one of the oil passage port. (could be blocking up the oil to the valves?)
R&d flexplate (could be imbalanced/misaligned?)
flushed trans fluid. filled the TC with 2 quarts before install.
Derale deep trans pan.
2 quarts of stop leak 20 quarts of transmaxx
theres no leaks except that one bolt on the pan that is stripped. Ill replace it with a longer screw later.
Ive tried looking up similar problems but I only see PSD problems with low fuel pressure. Anyone have any idea? It didnt knock when it was barely warm and hammering the throttle blowing smoke.
The mods:
