Intermittent Start but runs good when it does
ihc1470
Idaho
In your very first post you said you had fuel. Do you? Have you rechecked to make sure?
Beef_Cocaine
Cordova Alaska
When I ran yesterday and today I was not getting fuel initially on the first start up in the morning without the added ether. Throughout the rest of the day I had fuel but when it sat stopped for longer I had to give it some throttle on start up to keep it going.
asmith
Atascadero, Ca
You could run a fuel line into a jug and try to run the truck off that, to eliminate all the stuff before the pump. Maybe that could help you narrow down if you have a fuel delivery issue or not.
IDIBOBS
Southern California
How do you know you were not getting fuel?
Still sounds like a glowplug issue to me. If it was a air problem, it would start right away and then stall. That is because even though you have air in the fuel lines, you still have fuel in the injection lines. Fuel will not drain back out of the injection lines.
Something else I am finding out about diesels; They do not like to run on just ether only, they need fuel with the ether. That tells me you do have fuel, and the ether is helping it to fire because there is not enough heat in the cylinder.
If you are confident your glowplugs are working, then it might be a low compression/worn out engine problem.
Beef_Cocaine
Cordova Alaska
Turns out it was the glow plug relay. Starting just fine now. I went through 4 of them from Napa. None of them worked. I called a yard in Bellingham WA and they pulled one (stamped made in the USA on it) sent it up and now it starts up without having the block heater plugged in
IDIBOBS
Southern California
To each their own
Ether is a tool
So is a large impact wrench
Both can break things
Both have specific uses
Just my opinion, we can agree to disagree
This is the problem with this world. Ether should never be used in a diesel. It ignites. Diesel does not. You’re basically putting gasoline in your intake. Ether is a band aid for a problem that you don’t know or are unwilling to diagnose and repair. It has no place in a diesels mechanics tool box.
IDIBOBS
Southern California
I’m figured that from the beginning. All these guys jump to bad motors and what not and do t start at the beginning. Glow plugs/controller/wiring must work correctly to start these trucks reliably. It’s very rare to have actual mechanical issues result in a no start.
ihc1470
Idaho
One has to also go with what the poster says has been done. Very first post said glow plug system had been tested and all was fine, plenty of fuel, block heater plugged in, no air found in fuel system, etc. That was the reason a starter was suggested as a possible issue. There are ways to test startering systems before replacement, as I hate throwing money at an issue just on a guess.
Glad to OP got things sorted out and going again.
KansasIDI
I hate printers
Wilsey, KS
I’m willing to agree to disagree. The question is, are you?
miked
Bruce County Ontario Canada
Right from john deere.
My 3130 had a port to screw on an ether can right inside the cab.
Never used it as I kept it plugged in.
But this set up was not unusual and I knew farmers that used ether for years without disaster.
Yep. There is a lot of equipment out there that had optional ether kits that mounted under the hood and had plumbing that routed the ether to the intake. Of course those engines did not have glowplugs.
