Well that would be a major problem right there. Your timing is WAY off....
wouldn't that make it exactly 20 deg off?
Well your timing method is spot on. You ARE using the upper probe hole (the taller one) not the bottom one, correct? Can I also assume you have never unbolted your pump timing gear cover? The shaking at idle is a dead giveaway that something is not right. The injectors you are using... regardless of new or old, you have pop tested them to verify they are good?
I can't get the timing probe seated fully, so I can't get an RPM reading. I have the probe in slightly past the compression ring on the probe itself but the meter says 10 RPM. I can't get it to go any deeper, even with pliers.
I'll be doing that this weekend most likely.
