Installing E pump.
Ididriver
Panama city beach
My electric pump arived today.
Here's what I know I need so far and I'm picking up tommorw.
Chevy block off plate from a chevy 454. A inline 5amp fuse
A 4pin relay( not sure what exatly to get tho) I also realize I need to make a bracket.
Have to pick up a few 90 degree bends with barbed ends. And a few feet of 3/8s fuel line.
Is there anything else I'm missing?
Optikalillushun
Coal Region, Pa
A standard bosch 4 pin relay is all ya need. Any parts store should have one on the shelf. If ya need help as for a horn or fuel pump relay. I would also suggest ordering one (of a few to keep on hand) of these:
Its a common relay pigtail pre-wired. Makes for neat wiring. I would also add an inline fuse holder or fuse-block as pictured, wire loom, zip-ties, some heat shrink wrap and electrical tape.
redneckaggie
rebel w/o a cause
angleton/stephenville tx
If you have to splice into plastic line make sure to get some inserts for the line so you do not crush it when tightening your hose clamps, if you use teflon make sure to keep it off the first few threads and wrap it the correct direction. other than that I think the above post covers the rest
Ididriver
Panama city beach
ok heres what i was able to pcik up today.
i got a role of wire conduit to cover everything when im done.
a inline fuse holder rated for up to 30 amps and a 5amp fue to put it. along with a box of 5 amps fuses to keep in the truck.
and a 4 pin relay. made by bwd. going to return it if napa has the bosh one.
my local autozone did not carry the block off plate and advanced auto wasnt smart enough to find it on there shelfs.
so im going to go intown to hopefully get a diffrent relay. block off plate. and about 5 foot of 3/8s fuel line.
Summit or any hot rod shop will have a nice chrome block off plate. Check the fitment carefully. It is sometimes necessary to grind just a wee bit off the end of the block off plate, where it needs to fit into the slight recess in the block.
Ididriver
Panama city beach
Thanks Mel but I just got one from oreilys. Nice shiny edelebrock block off plate.
Man I'm getting pumped for this install.
Only things left now are 3/8s fuel hose and fittings with barbed ends.
On the fitting that goes into the fuel filter I'm hoping to get a 3 way so I can relocate my fuel pressure gauge there.
I'm off to start making a bracket for it now.
rhkcommander
Oregon
You can use female spade connectors on a bosch style relay if you cant find a prewired socket
Ididriver
Panama city beach
I think I'm over complicating this...
Ok the relay has 4 pins(duh) I take a male connector to connect to the outlet of the pump and that goes to one pin on the relay.
Then I take a ground wire and put it to another pin on the relay.
Then a constant power with the inline 5 amp fuse to another pin.
Then finally the last pin goes to fsv am I right here?
Then it's just as simple as pulling mechanical pump off putting block of plate on and attaching fuel lines.
maddenji
Burlington,MI
Just a thought.
I picked up an inertia switch from a ford station wagon and wired it inline to automatically shut off the fuel in case of a collision.
It's inexpensive to do.
Jim
Ididriver
Panama city beach
Just a thought.
Jim
I may just do something along those lines after I get the pump on and know it's working properly.
I was thinking more along the lines of having it stop if oil pressure drops below say 7 psi
gandalf
Senior Member
CA &/or Maine
I believe there are several ways to hook up the relay. I went through past posts and found five variations, from the four spade connectors.
I THINK this is the way I did it, and was approved by Calvin. The terminals on the relay are numbered, 30, 85, 86, 87.
30--to the battery, with an inline fuse.
85--to ground
86--to ignition (wired in to the FSS on the IP)
87--to the fuel pump
That being said, I'll go out and check on the truck itself, after I have a bit more coffee.
ON EDIT
Disregard what I said above. I looked at the relay itself, and will correct things.
30--to groung
85--to fuel pump
86--to FSS
87--to battery.
As I said, there are a number of ways to wire these things, and most of them seem to work. You just have to pair the right terminals together.
Ididriver
Panama city beach
Thanks gandalf.
Ok last question I have before instal tommorw.
Const power from battery. Best place to splice into for that?
And for the fsv. What's the best way to do that?
Wyreth
Certifiable Noob
Las Vegas, Nv
For constant power, I would simply use a ring terminal, and hook into the hot side of the starter relay. For tapping into the FSS, I would use a shim, pull the spade out of the plastic. Then solder onto the back, then put it back together. You can also use a U spade connector to give yourself another spade connection at the IP.
But that's just me...
gandalf
Senior Member
CA &/or Maine
Thanks gandalf.
Constant power from the battery-- I too took it from the starter relay on the passenger side fender. For the ignition power from the FSS, as I recall I replaced the spade connector and added the extra wire when I crimped it shut. I did this very carefully because there is not enough extra wire to allow for a mistake.
