installation instructions for injection pump?
912504x4
Troy IL
I am going to try installing a fuel injection pump on my 91 7.3 and wondered if anyone has the install instructions available for me. I have put PBblaster on all the fuel lines and bolts that I can see so hopefully everything will cooperate with me.
I dont have a Haynes manual or anything but I do have the ability to do this as long as I know the pitfalls first.
Do I need to prime the new pump or anything like that or will the fuel pump cover that?
Should I roll it over to top dead center first or does that not matter. Seems like the pump will come with a keyway for timing but I wasnt sure.
Is there anything else I should worry about or get on order before I do this?
Thanks, Eric
94f450sd
somewhere,ma
in that article it says you need a 16 point socket to remove the 3 bolts holding the gear to the pump.that is wrong you need a regular 12 point socket.also DO NOT remove the pump gear housing!!!!!!!!!!
crispy74
