Install complete, home made catch can and intake.
Sycostang67
Scooty Puff Junior
Kuna, ID
Today I managed to get my new intake system and the oil catch can I made installed. Everything went together like it was a kit made for my truck. The turbo sound in the cab has really increased and my catch can is already doing it's thing. I also tossed in a new set of motorcraft plugs while everything was clear. If you want details on my catch can, they are in here. http://www.oilburners.net/forums/sh...-catch-can-would-it-be-better-with-a-breather
Here's some pics.
I did put clamps on the hoses from the CDR and catch can, I just hadn't located them yet at the time of the picture.
It's pretty.... the million dollar question is how does it work?
Sycostang67
Scooty Puff Junior
Kuna, ID
The filter is a spectre brand K&N style knock off cone filter.
My butt dyno is telling me that throttle response has definitely improved. It sounds a lot better as well. I figure anything is an improvement over trying to suck air through the oil soaked paper/foam filter in that funky ATS box. I'm really hoping the catch can will do a good job of stopping so much oil from going through the turbo. The main reason I did this was all the oil coming from the CDR was soaking my air filters and had completely permeated the boot connecting the turbo to the air box. It was so slimy that the clamps wouldn't hold it. When I removed it this last time, it had partially sucked the boot off the turbo lip and was working it's way into the blades. I already have some oil accumulation in the can, so it's looking good.
vandy7.3
wardsville, missouri
Where exactly is the filter located? Might be a stupid question, but I don't see where it could be according to the pictures. And I like the setup might try to duplicate that on my truck once I get the turbo installed
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Sycostang67
Scooty Puff Junior
Kuna, ID
The filter is located inside the large cylinder in the middle, between the two t-bolt clamps.
vandy7.3
I see... I'm trying to figure up some way to fab up a CAI and I like what you did with the intake. I'm not going to bother with the catch can, I'll just make an RDT. But you say it's just a normal cone style air filter inside the stainless cylinder? I'd be interested to see how you put that together. I'm just against the factory air box and I don't want to just run some pipe with a filter hanging off the end sucking up hot under hood air
vandy7.3
Well ain't that something.
I never knew they made such a thing. Ive been wanting to do something like that with an inline filter and route a pipe to draw good cool air. Ill be ordering one of those.
Thanks for showing me that
NO_SPRK
User & Abuser
Santa Rosa, Ca
sweet write up! ive always wondered about a setup like yours. works great with the cowl intake.
do you plan on wrapping the air filter housing to help from engine heat?
pep boys sells spectre stuff too
Sycostang67
Scooty Puff Junior
Kuna, ID
I never thought about the heat wrap, that's a pretty good idea.
I got a few more pics. Here is the bracket that allowed me to mount the filter to the valve cover using an existing CDR retaining bolt.
vandy7.3
Love it, I ordered the inline spectra filter today. I'm gonna make it where I'm drawing air in from the factory location right on top the radiator support.
That is an awesome setup kinda surprised more people don't go that route, turbo or N/A
Sycostang67
Scooty Puff Junior
Kuna, ID
I have only known about this air box for a few weeks. I was looking through a catalog for tubing and ran across it. It worked out better than I had hoped. The filter and the blue boot(odd size, 2.75" to 3") were the only parts I had to order, everything else was available at the local auto parts store.
NO_SPRK
User & Abuser
Santa Rosa, Ca
Only thing im wondering about is why you put shut off valves on the filter if its only for blow by.
Sent from my SCH-I605 using Tapatalk
Sycostang67
Scooty Puff Junior
Kuna, ID
Are you sure you aren't looking at the coolant filter? I don't have any valves on the catch can.
ntjapkes
