From the looking around I've done, it seems like the o-rings most people use are McMaster-Carr 9464K24. They're Viton, dash number 111 with a durometer of 75A, listed as medium harness. I'm guessing these are what ship with the good return line kits from Conestoga and others.
But McMaster also lists a soft version of the same o-ring with a durometer of 60A. The description says the soft rings offer a better seal in low pressure applications. The McMaster number is 1284N14. Does this seem like it might be a better option?
A little background on why I'm asking: I recently replaced my return lines, caps, o-rings, fuel filter, and olives. I was still getting air in the system. I noticed the cap on injector 1 wasn't fully seated. Seems like I would have noticed this during install, so I wonder if it popped back up somehow. Anyway, I pushed the cap back down but I'm still getting a lot of air in the system. I figure my next step is to pull the caps back off, look for damaged o-rings, and try to seat the caps again. I'd like to have o-rings on hand, so I figured I'd order some.
Thanks.
Thanks.
