goatwrangler
Hey guys will a IP off of a 1991 f250 N/A with an auto tranny work on a 1991 F250 N/A with a 5 speed
Yes.. And yes there is a differance... On the drivers side of the pump there is a shaft that turns as you increase the fuel which in turn increases the rpm... On the standard trans injection pumps there is a small roll pin thru that shaft. Thats all the differances. You just remove that pin and you can install the E4OD tps switch with its connecter and you have what you need. I'm not familiar with that side on the C6 trans but I do know the VVR is located on the same shaft.
If the IP comes with the TPS for the automatic trans you can either remove it, or just leave it unplugged. Just so you know, the bolts that hold the TPS bracket to the IP body like to seize up there, so you may not be able to remove it at all... Either way, your truck will run just fine with this IP.i have the 5 speed so i shouldnt have to do this correct ?
