Simp5782
SNOW TACKLER!
5 tons with the multifuel with 11.00s can get about 9/11 depending. with the 250 cummins 4 - 6. they arent that great. the cummins is more reliable and cheaper to work on but lacks the fuel. The multifuel is very load. even the cummins is pretty bad and have to wear hearing protection
the 5 ton dump is an 817. the air noise ur hearing is the sprag. the air shsh thing into reverse is the sprag locking in. then you have to go to neutral and then into 1st and the sprag will lock into forward. when the rear tires slip the front will lock. its kinda a crappy design.
