Putting a turbo 6.9 IdI
pwillis
Ohio
I am putting a new engine in my 1992 ford
f super duty.
The new motor is a 6.9 idi I am throwing around the idea of putting a 73 power stroke. Turbo on it or possibly 2 turbos.
rreegg
IDI n TDI
Puget Sound
I don’t think the power stroke turbo is viable based on previous times this has been asked - you are welcome to prove us all wrong though. Easiest to just use an idi turbo and save the time/money/fab efforts and sanity for other projects
Good luck and double turbo would be awesome
pwillis
Ohio
I would have liked to use the factory, IdI turbo. But the engine and transmission I got had the industrial bell housing. Which will not allow me to use the factory up pipes. So i've already made headers to suit my situation the only problem I'm not sure about is If the twin turbos, we'll spoil up in a reasonable amount of time.
pwillis
Ohio
He's a member on here and that's his screen name. He's not real active on here lately though.
rreegg
IDI n TDI
Puget Sound
Came across this video this past winter and he says himself it's a pretty redneck twin turbo build but it works. at the very least it might be good inspiration and maybe will help with other things
pwillis
Ohio
That is exactly what I was planning on doing. Thank you for sharing that video!!
Olds64
Edmond, OK
Excellent! :Thumbs Up
Necessity is the mother of invention. I was dumbfounded when he expected 35 psi of boost.
Ford used 2 different turbos on the 6.4l PSD and VGT to eliminate turbo lag.
Jimacho
