Simp5782
SNOW TACKLER!
Ok, so I finally have the motivation and need to get it done before winter. I have a 1962 M-61A2 5 ton 6x6. It currently has a very sickly LDS-465A1 in it. There is youtube link below to it idling.
I picked up a 87' 6.9 NA from a 4x4 school bus with 110k miles on it. Complete with a 15" clutch pack that went to a spicer 4054 tranny. Includes all brackets, accessories, exhaust, glow plug controller, wiring harness, etc for $500.
I am thinking my only problems are going to be getting the exhaust around my drivers side front driveshaft, as well as a fan setup. The radiator in the 5 ton is mammoth and holds 18 gallons of coolant by itself. So I will be looking into running a electric fans more than likely since it is a mammoth area. Making an accelerator cable system for it since my truck currently has a rod linkage that is near the pedal. Making an air compressor system for the air over hydraulic brake system. I have the compressor off of mine just need to find a way to make a mount for it. setting up a power steering system since I do have power steering right now but the pump is gear driven off the engine.
As far as power rating though the NA idi is very comparible to the turbo LDS
6.9 NA 170hp and 340ftlbs @ 900lbs
LDS Turbo 478ci 6cyl- 175hp and 425ftlbs @ 1800lbs and 2650rpm redline.
Transmission ratio is .85 in 5th direct so unless you are running big tires you wont be able to go over 50 without blowing the multifuel. The reason I am looking at the idi swap is better reliability over the multifuel. Parts availability (being able to go to napa for parts vs having to wait for a surplus dealer to ship), easier to work on, ALOT quieter (the multifuel will have your body vibrating after you drive it and cant be driven without hearing protection.)
I attached some pictures of the engine in the bus still in the bus. As well as my LDS in my 5 ton. Going to be doing this project over the next few weeks so I will keep some updates going. First 2 pics are the LDS the rest are the 6.9 in the bus.
http://www.youtube.com/watch?v=uBfwqsL11o8
