tractorman86
so here is my dilema: i have a 1991 250 i am rebuilding, i have two suposedly running 7.3's or a bare 6.9 i had $2,700 worth of machining done to it(sleaved to std., crank and rods all magnafluxed ballenced ect. i am also going to drill&tap heads and block to slap on 7.3 studs for extra strength:Sly ). i let a so called friend of mine do my bidding and was told the motor was a 7.3 but was infact a 6.9 . is there any reason i shouldnt bore out this motor and run 7.3 pistons in it? (going to get whichever ones i use ceramic coated via ken :Sly ) it is only .11" after all. if u havnt noticed i am planning on adding a lot of power adders; turbo(possibly a 6-71 instead), water/**** inj, propaineinj/nos, intercooler and so on and so forth. well i guess i've rambled enough, should i put the 6.9 togather and sell it while doing the same work to the 7.3 or just run it since i am already this close? any ideas yall?
any help i can get is GREATLY APPRECIATED!!!!!!
