Hypermax Cowl Induction Installation
Status
Not open for further replies.
BrandonMag
Dana 50 rebuilder
Oregon east
First off, I'd like to say thank you to Hypermax for the high quality made in America product!
This is a really simple installation project. I'm definitely no professional metal fabrication specialist, and I was able to do this start to finish in less than two hours.
First, remove your stock intake inlet. Next, place the plastic cowl induction horn on the firewall, grab a Sharpie and mark the inside of the horn on the firewall. (I had to grind off about 3/16" of material from the bottom of the horn so that it would clear the lip on the firewall.) On my firewall, I had to cut some of the sound suppression material away and I had to remove a vacuum line/wire harness holder:
Next, cut the firewall. I don't have a torch or plasma cutter, but I've got a 4 1/2" grinder! Here's what the area looked like after I made the two horizontal cuts:
After trying to use a Dremel tool with a wheel for the vertical cuts, I reshaped one of the many cutoff wheels I've got for my 4 1/2" grinder so it was small enough to make the vertical cuts. The inboard cut was fine, but even with my smaller cutoff wheel, I couldn't position my grinder to be able to make the outboard cut. After monkeying with the metal for a couple of minutes, trying to figure out what to do, I just worried it until it broke. Not the best way to cut metal, but it worked.
The plastic horn came without holes predrilled, so I carefully laid them out and drilled the horn, then marked their position on the firewall with my trusty Sharpie. The outboard two and the top inboard one were a piece of cake to drill, but the bottom inboard hole was angled so that I really had to hammer on the firewall with a punch to be able to make a big enough mark to start the drillbit with. The only thing about the kit that was kinda chintzy were the screws. They're not of a very high quality. Fortunately, I had some panhead 1" wood screws laying around that worked great. Hypermax includes a sticky black adhesive to apply to the firewall side of the horn. I just stuck it to the horn and maneuvered it into place. After that, you've just got to spin on the ductwork. I spun on the air cleaner side end and manhandled the cowl induction horn side on:
So far I've put about 230 miles on the truck, and I really like the sound improvement. Much more throaty intake sound. On my truck, the PO had a set of headers with long glasspacks installed but had left the intake stock. This cowl induction mod has made the exhaust note slightly throatier.
All in all, I'd recommend this mod to anyone with $100 and a couple of hours to spare. ;Sweet
EDIT: I just remembered, I also installed a drilled-out air cleaner hat that had the soup bowl removed (you can see it in the third picture). My thinking is that more air = more power. However, this will draw in (a small amount of) hot air from the engine bay. Is this a good idea?
Now you need a turbo. Wait I have your turbo.LOL.
grog85
novi,mi
I think you would be better off without the holes in the air cleaner lid. Yes, it lets in hotter underhood air, and it negates the ram air effect at higher speeds .
LCAM-01XA
my very own hell
Not just that - it can also let water in during heavy rains, and you definitely do not want that to happen!
RLDSL
Diesel fuel abuser
Arkansas
Congrats on the new arrival. Next time you need to make a cut like that with a wheel in a confined space , make your long striaght cuts, dig in the short ends best you can, then make a diagnol cross lengthwise and you will have a couple of big Vs that willl easily wiggle out at that point.
Diesel JD
Gainesville, FL
I'd think whether you're turbo or N/A that cowl induction unit needs a low point to drain off the water in case you have to operate in heavy rain. I'm about ready to install mine now that I have a little more time. Just have to take care of a couple more pressing matters first and maybe find someone with better tools than me to cut the metal. My best metal cutting tools are a hacksaw and a dremel, or a jigsaw with metal cutting blades, neither of which seem likely to work well in that situation.
Sycostang67
Scooty Puff Junior
Kuna, ID
The cowls have there own drains and my turbo airbox has a drain in the bottom as well, not sure about the N/A filter housing though. I haven't had any issues with rain or snow yet.
RLDSL
Diesel fuel abuser
Arkansas
The factory N/a air filter box should have a drain at the back with a little rubber one way valve to let water out
Diesel JD
Gainesville, FL
RL you have the ATS 088 like I do.... do you know if that box has a drain/low point to let the water out. I think my cowl drains are clogged, most of the water actually runs down the firewall and into the floor board where I cut the hole for the mechanical clutch rod if it's really a deluge, other than that things seem to drain really quite well.
TWeatherford
Flagstaff, AZ
Nice post. I've heard of it, now I see how it works and want one. Dunno if my early Banks turbo airbox has a drain, but if it doesn't I bet one can be added.
THECACKLER
Da Central U.P.
RDSL - Good Tip on Tin Cutting... (I love my Sawsall...)
And for those that don't have even a Dremel.... I have seen it done with a small drill bit. Just a row of holes. The edge can be cleaned up with a file. Hence, small drill bits. This perforation method also works for bending sheet metal on a line.
Status
placidoert
Staff online
