How to use a PSD Downpipe on your IDI factory turbo
Status
Not open for further replies.
Spader
Rusty the Ford
Alberta
Yeah, some of the joys of living in Canada. Shipping was $65.00 from banks if you can believe that. It did however come with a nice pre-welded fitting for a EGT probe. The rest of the exhaust I'm gonne run by myself. 4" straight pipe full length .... welded w/no clamps
Again controversy on should a EGT probe be fitted into the manifold or into the DP? I gather if you have your pyro in the DP you have a collective temp of the entire engine, not just one cylinder.
Dsl_Dog_Treat
Decatur,MI
I drove it before and after the mod doing some work on it for Ty and it runs out really nice.
oreocreaming
madera, ca
A bit off topic .... but you mentioned the "Factory ATS" Turbo. Mine says Garrett right on ther side of it. Did ATS produce all 1994.5 Factory Ford Turbos or were there some Garretts in production as well??
Thanks!!
I think I found one of the last Banks DP in exsistence to bolt up without having to build my own. It was $160.00 canadian and is 3".
garrett makes the turbo that ats had them design. ats just made everything else and designed the kit. almost any kit you are going to find for any engine is going to be made by garrett.
Spader
Rusty the Ford
Alberta
Changing the DP and running straight 3" exhaust mad this into a new truck. A HUGE DIFFERENCE ..... still can't seem to get more that about 7 LBS boost but the truck still has more than enough jam for me!!
oreocreaming
madera, ca
have you adjusted the wastegate rod? if not then thats your next step.
swuchase1
La Mesa, ca.
I am NOT hi-jacking this thread it is juat a good place for my question SORRY. Where do i check boost presure and how do I turn it up I also have a ATS system
Status
