How is my truck even starting?
chris142
SoCal
I have noticed that my truck has been cranking slower than normal. Ran over to battery mart and had the batteries tested.
One is doing 230A and the other 350A. How can it even start?
nostrokes
Colorado
When my batteries crapped out I swear I could spin it by hand faster than the starter but it always started. Kept it warm with the block heater and made sure the fuel system was good and tight till I got some new batteries.
chris142
SoCal
fortunatly it does not get that cold here. Plus I dont have a block heater.
chillman88
Central NY
When I picked mine up in Texas it seemed like all it could do to turn over. Replaced the grounds and it got a little better. Little by little, timing adjustment, a new starter, plus a few little odds and ends and now she spins right over but when I first got her it always sounded like it was dying. I couldn't believe mine started either!
Macrobb
North Idaho
If the IP/injectors/glow plug system is in really good shape, it'll fire within a couple of revs and you don't need much battery.
If not, well... you need a /lot/ more battery.
I've started IDI's with one battery before; if the battery is in good shape(or it's warm), it's fine. If it needs much cranking... well, that's why you have two.
chris142
SoCal
ya well with the help from people here I have fixed bad connections,have the proper glow plugs and timing as close as possible.
