How good or bad is the E4OD?
  • I have never been around them, but have heard good things
    Votes: 0 0.0%
  • Total voters
    22
david85
Campbell River, B.C.
That line pressure droop must have been quite the engineering project back in 1989. I can imagine the kind of arguing between mechanical engineers on the merits of that. These days its easier to accomplish simply by throttling down the engine near a shift point. Which still makes for an awkward driving experience in many vehicles. The 6.0/5speed auto in my Dad's F450 seems to get it right but I don't know if it has bone stock transmission or not.
One mod I saw recommended by a former Ford engineer was to take the cooler from a later 6.0 diesel track and install it in the older ones. Apparently ford got so fed up with cooling issues on the 4R100/E4OD that they went overkill on the later 5R110.
I just went with an aftermarket cooler on mine: https://www.amazon.ca/gp/product/B000C3BBKS/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
The trans shop that built my in laws E4od also said the same thing about the 6.0 cooler, and sold me one.
Rdnck84_03
Kansas
I will definitely confirm this as a drastic improvement. When we bought my wife's 2000 powerstroke it had a fresh rebuilt 4r100 with the tugger hd2 shift kit, and the cooler bypass delete done.
In 100 degree plus weather just stop and go traffic would set off the trans temp warning on the edge monitor. I think it trips the warning at around 225 degrees. After the 6.0 cooler install the highest temp I have ever seen loaded was 176 degrees. Stop and go driving now is usually around 145 degrees.
Not sure what is required for install in any of the idi trucks, but the 7.3 superduty just bolts in factory location.
James
ISPKI
Granby CT
I assume you could now make the connecting cooler lines using Nicopp. Easy to form, relatively cheap, handles around 5,000+PSI at 3/8 diameter. I usually put a little curly coil of it somewhere to help eliminate fatigue from flexing, although given the length of run that probably isnt necessary for this application.
Black dawg
sw mt
Had the 6.0 trans cooler in my pickup before I went manual. Was plumbed before cooler in radiator. Even with converter unlocked, transmission temps never went much over 200 degrees.
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
Well the truck I was looking at that has an E4OD unfortunately has low compression. I don’t need another project. I’ll just have to keep my eye out for a decent 84-96 crew cab. Diesel or 460. Sacrilege to say that I would be satisfied with a big block lol
Nanohawk
