I 100% agree with all of the above posted here. Will be taking it to the machine shop soon. The heads have already been tested, decked and rebuilt. There was a small crack between the valves that magnaflux picked up. Under pressure test it did not leak (don't know how I feel about that). I thought I was just going to replace the headgaskets but here I am. Have to make sure it's all good.
Nice tear down. What I see is a need to line bore the block for the out of alignment mains. any time you see wear like this it tells you that is a high spot so that part of the bearing wears thru. The rods appear to show wear as if this engine may have had tooo much timing advance. Others may agree or not with this. also the thrust bearing shows some wear it should not. the crank is being pushed back in the block to wear the thrust like that. Finally that last pic might show excavation on the cylinder or it had a small amount of water or coolant sit in it so it rusted the cylinder. That last main journal looks like so water laid on it for a time too. Might want to see if polishing the rods and main crank journals can clean it up. these are slow rpm engines and the cranks are very hearty. the seldom rear out. Same goes for the original oil pump. they most never get replaced because they are high volume low pressure pumps. And the new Melling pumps are not as good as these original pumps.
When I was new to the idi I 100% put this motor through some abuse. A period of maybe 10k miles or so. I had the timing on IP way advanced, heavy fuel and trying to get my EGT to not climb so fast
The thrust bearing shows wear on both front and back bearing surfaces. 100% the first and last crank journal show surface rust. I do see some wear spots on mains. Is it normal to see heat spots around where the main bearings would be? Hoping a polish will take care of the crank. We shall see. I'm pretty sure a little water got in the cyl there is some surface rust there.
I'm not looking to make crazy power or dump a bunch of money into this rebuild, but a runner and able to handle the 10-15 psi from the banks kit without any issues would be nice
