zigg
I had a lot of slop in my steering(about 4 inches), and couldn't find anything specific, so I got another box from the wrecker that appeared to have next to no play in it, and decided to swap it in.
The old one didn't want to come out at all. All ya gotta do is pop the ball joint off with a puller, 3 bolts on the frame, and slide the thing down...(not)
Some previous owner had bashed the thing, and it was badly bent/dented at the slip joint and just wouldn't slide apart. I spent 2 hours banging and fighting to get it out. had to finally remove the tire, and cut a huge section out of the wheel well to get at it, and then finally drove it out with a prybar and mallet.
Anyway, once out, it became evident what was wrong with it. The rag joint was nearly liquified. It had become saturated with oil/grease etc, and was so sloppy it finally just came apart in my hands. THAT was scary. There was no discernable play in the steering box.
After I changed my pants, I put the new (used) one in with a nice tight rag joint. Took about 20 minutes, and the difference is amazing. Maybe 1 inch of play now, but mostly I think I'll sleep tonight knowing that I removed that sloppy thing.
I highly recommend anyone who has the "classic Ford sloppy steering" to check the rag joint before you do anything else.
Zigg
Zigg
