turbonator
gm diesel guys, AKA turbonator
i am wondering if i can use a hx-40 turbo for a 6.2l will this turbo spool quickly on a 6.2? i know that 6.2l is only 8-10 psi boost, and pyro below 1150, any help is appriecaited thanks in advance
You will never spool an HX-40 on a 6.2...IF you must try it, try to find one with the 16cm housing it's the smallest they came with IIRC...you would be better off with an HX35 or even better an H1C from a 1st gen cummins...If your H-bent on the 40 I got one out on the shelf I'd sell
eh the H1C is prety big and slow to, i put one on my propane powered 345 in my scout and it take a week to spool up to 15 lbs ,
Every turbo listed so far is way out of it's MAP when only run to 10 psi. Not very efficient, but they will work, one way or another.
