steelheadguy
Registered Idiot
I noticed gear oil coming out the brakes so now I am attempting to replace the seals.
Sterling 10.25
I've managed to get as far as taking the hub nut off. I can't seem to get the hub to come off. I'm using a 3 arm puller hooked onto 3 lug nuts and pushing against the axle tube. It seems like it should slide right off, but Im using so much force I'm nervous to crank it anymore.
Am I missing a step? Should I pull out the outer bearing somehow? Is it just stuck? The hub nut is off shouldn't it come off?
Thanks for any help my truck is on a jack until I figure this one out.
Sterling 10.25
