Got some more done today
Exekiel69
I got the chance to do a few things today so i replaced the rear main seal just in case, then the rear gasket, the to bearing for the clutch and a new bushing as well.
I removed the oil pan and re-sealed it, I painted it at the same time since it had a little rust so I cleaned it well and then painted.
I Adapted the oil pressure, water temp, boost outlet, Pyro and tach then some wiring as well. The good thing is that the cummins engine does share some of the sizes so no much need for adapter for some of the sensors, the other I had to drill and tap.
Exekiel69
Some more pics here for the after the installation.
Exekiel69
At this point I'm almost ready to drop it IN, just need some insulation for the firewall. I see if I can get some today and maybe if I'm brave enough I get it done to that point.
Exekiel69
Wow is this a new feature? You guy keep changing the forum but just don't change the address with out letting Me know please.
I didn't get an answer but I'm hoping it will work, if not I just plug it and put the pick up some place else but I had to at least try.
argve
Resident Fruitcake
Gwynneville, Indiana
EZ,
You're looking good my friend. So I expect to get a ride in her over the coming July 09???? I would really like to see what she can do.
Exekiel69
Well You got Me started, You got it Man.
I will have to rebuild the getrag Myself since the cost to have a shop doing it is too high for Me so with a manual I got from someone else I'll give it a try. I will also post pics of this.
Today I'll re-do the wiring and put some heat shield so I can drop the engine and get started with the gutbug.
