Sycostang67
Scooty Puff Junior
Got another IDI in the family. (Now with carnage pics)
My sister thought an IDI would be a good vehicle for our parents. In some ways yes, in some ways no, regardless we have it now. It's a 1991 F-250 super cab with an N/A 7.3 and a 5spd. She bought it unseen from a local auction for about $1500 after fee's and what not. I wish she had looked at it first because it needs a lot of work. The motor and transmission seem solid, idles smooth, plenty of power, no smoke and almost no blowby out the filler cap. It looks as though the PO was out playing in 4wd when the driver side u-joint let go and bound up causing the front driveshaft to turn into a swirly cone. It only has one battery, cable was hacked off so I can't hook another one up, tach sensor wires cut off, return lines leak like crazy, glow plug harness is busted in a few places, there is actually an extra battery cable coming off the controller to connect to the battery to run them. The ABS light is on but someone painted over it so they wouldn't have to see it. The Engine light is on as well, though I have no clue what that could indicate. Oil pressure gauge doesn't work, windshield trim is gone, core support has been cracked and rewelded, aluminum spacers under the hood hinges and latch. It has an aftermarket oil pressure gauge and the pressure is good, the oil is clean, but the coolant is really dirty and has some RTV floating in it from a crappy water pump job. The motor only has one small oil leak from the front seal though. Expect to see some questions regarding this thing popping up.
