Gear vendors on a 4x4 crewcab???
fiverpuller
Lizard Limo
Portland, OR
It doesn't look there is room to me...about 1.5" above the u-joint to cab structure. I remember reading you have to notch the cab to fit a US gear. Anyone install a GV? I have one and am debating if I want/need double od. If I only had 3.55's I would just sell it. I don't think there is any way I would take a sawzall to my cab. cookoo
beretzs
Midway Park, NC
My GV fit just fine no cutting involved. I have the Crew Cab also. I think you may have to shim out your carrier bearing, but other than that, it should bolt up fairly easily. Scotty
fiverpuller
Lizard Limo
Portland, OR
It's just the standard gv...current type. I don't have the adapter yet or I would test fit. I guess it just doesn't look like it will work...but it must. I am just rambling here. cookoo I found some dimensions on the gv site so it looks like if I am at least 4" from output shaft c/l it will fit. Scotty...do you have the 1356 t-case? I would like to go divorced but I haven't got an official quote on the front adapter.
Apparently I can't send an attachment from work so here is the link:
gv dims
Here is what my GV looks like hanging on the end of my 1345. Not anywhere close to the cab floor.
apextrans
What Log Book????
Fallston, MD
I've got the whole setup....adapter & all. I'll be installing this week coming hopefully & I'll post some pictures. I've read the install instuctions & nothing about cutting the floor.
fiverpuller
Lizard Limo
Portland, OR
I measure the bottom of the cab to the c/l of the yoke and it's right at 3". So it looks like it would rub...but not a full collision. Maybe I could lower it some with a shorter tranny mount. Or do a 1" body lift. Or just hammer it a bit to gain clearance. I was wondering if maybe the cab mounts have sacked out a little over the years. The cab looks lined up with the bed...but feels squishy side to side. Sometimes it feels like riding in a freight truck. Who makes cab mounts besides ford?
jlayne
Bondo Bandito
Milledgeville, GA
i had a old truck back when i was in highschool that i replaced all the body mounts with a stack of washers... it wasn't for lift or anything, i just didn't have the money to put new ones in it and my truck was saggy, the truck also had one hell of a cam in it and every time it would lope at idle it would shake the holy hell out of everything.. it was quite cool, but i think a diesel might feel like a rolling vibrator without the rubber pads
on another note many many many jeeps have had to lower the drive components to get rid of vibrations.. most of them do it by dropping the tranny crossmember down a bit... i think this would be a easy fix to your problem without a body lift :puke:
beretzs
Midway Park, NC
I have the 1356 T-case and I have plenty of clearance on top of the GV unit. I will have to get out and take some pics for you tonight. Scotty
Bo17
