Ronnie9000
Howdy folks--
My 1990 F350 wouldn't start the other day. I had changed the fuel filter about a week earlier and driven very little since then (<10 miles probably) with no issues. So at first i suspected something was wrong with my filter install. I had zero pressure at the schrader valve. I opened the fuel line going into the fuel filter (the line coming out of the pump) and turned over the engine, expecting to get fuel spray. But i got nothing. So i thought perhaps it was the fuel pump. I verified that there was no obstruction in the lines up to the pump, so there was nothing else but the pump to change.
I bought a new mechanical fuel pump. Since then I have reinstalled the pump FOUR times, each time checking to see if it would pump fuel and each time being disappointed. at first i thought i wasn't positioning the cam correctly, but i have turned the engine over multiple times to verify that i am definitely getting the pump arm under the proper lobe.
Could it be that the new fuel pump is faulty? I know that it can pump fuel, because i put it in a vise and manually pumped fuel through it pretty easily. But i did notice that there is more side to side play in the new pump arm than in the old one--could it possibly have enough play that it is slipping off the lobe and riding on the non-lobed cylindrical part of the cam? Has anyone experienced a similar issue?
