ghunt
So I've been toying for awhile with the idea of adding an auxiliary fuel filter to my truck and/or swapping out the stock filter and head with something else entirely, especially with the new IP and injectors going on soon.
I had two concerns with that though...#1 I don't want to lose the heater in the factory filter head (though I have been thinking about running the fuel through the radiator tranny cooler prior to final filtering), and #2 I wasn't sure what to do with that "return line" or whatever it is that runs off the passenger side fuel rail and back into the head. What IS that for exactly?
I have an electric pump and I'm planning to run a 30 micron pre-filter for it...beyond that I don't know. I have a spare filter head from an old dozer that I have found can fit filters from 30 microns clear down to 2 (this is the same filter head on the pre-filter). I also have a Goldenrod Water-Bloc sitting on my shelf that I'm doing nothing with.
How viable of a setup would it be to run a 30 micron prefilter, through the electric pump, then through the Goldenrod, through the radiator tranny cooler and finally through a 2 or 6 micron final filter before it goes into the IP? Is that just way too much complexity? The spin on filters for the filter heads are cheap and the 2 micron filters are huge (7" long) which means they would almost never need changed if I did run one.
Don't mind me...
Don't mind me...
