My 29-year-old truck became "algae"-infested, definitely not from sitting, just from having three tanks and accumulation over many years.
Many many trucks are heavily infested with diesel bacteria; but, with the factory fuel-system it goes completely un-detected, mainly due to America's reliance on disposable "canister"-type filters that hide what is really going on in the fuel-system.
Also, these disposable screw-on can-type filters have no reservoir for sediment to collect, so instead, any sediment clogs the pleats of the filter.
With a proper sediment-bowl catching all of the big stuff, the filter will last a long time only having the fines to deal with.
Many is the fuel-stop that has been blamed for bad fuel, when what actually happens is the in-rush of fuel stirs up all the trash in the tank; two miles later, some of this **** gets sucked into the fuel-line and stops up the too-small fuel-filter.
Put a
CLEAR SEE-THRU sediment-bowl in the system, ahead of the actual fuel-filter, and it is completely educational just what all one will find.
Previously un-beknownst to me, there is a screen hidden in the inlet of my piston-lift-pump.
That screen got completely blocked with slimy fungus.
I installed a simple clear plastic in-line filter ahead of that screen and it was constantly getting plugged with the same fungus, commonly mis-named "algae" which it never has been, as genuine algae MUST have sunlight to exist; this stuff only thrives in darkness and will die when exposed to light.
After tons of research, I found that there was no magical cure available in a bottle; marine sites are loaded with information on this and the general consensus is not to waste your money on pour-in "algae killers".
What I have done, that has maybe not completely eliminated the "algae", but sure keeps the fuel going through my pump as clean as a whistle, is to install a gauntlet of filters and seperators.
First in line is a See-Thru Bottom-Drain GoldenRod seperator/filter; I highly recommend one of these and it is amazing how much filth settles to the bottom of it's bowl, before otherwise clogging any filters.
Next in line is a genuine LUCAS/CAV glass-bowl water-seperator/sediment-bowl; this catches any water before it gets to the lift-pump.
Connected directly to the LUCAS is a genuine De-Bug magnetic bacteria killer; I researched this heavily before plunking down my hard-earned cash and it sure seems to do exactly what it claims, believe it or not.
Next in line, as a final defense ahead of that hidden screen within the lift-pump inlet, is a plain old see-thru plastic in-line filter; I had much rather any trash stop within this simple-to-replace filter, than to clog that near-impossible to service screen while going down the road.
Last in line is the factory fuel-filter mount that has a water-seperating filter with integral bottom drain-valve; this drain-valve is actually made onto the filter; you buy a new filter, it comes with a new valve.
Since installing this array of fuel cleaning devices, I have not had one engine shut-down issue due to a clogged filter; and, it doesn't cost me a cent to rinse out a sediment-bowl, plus I can actually
SEE what is coming through my fuel-lines.
