The powerstroke filter in Wix:
Part Number: 51734
UPC Number: 765809517349
Principal Application: Ford/IHC Trucks w/7.3L Turbo Diesel (94-03)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 8.093
Outer Diameter Top: 4.282
Outer Diameter Bottom: Closed
Thread Size: 1 1/2-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=10/30
Burst Pressure-PSI: 385
Max Flow Rate: 28-30 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 3.967 3.587 0.340
The standard filter in Wix:
Part Number: 51742
UPC Number: 765809517424
Principal Application: Ford, IHC Trks w/6.9 Diesel Engine (83-93), 7.3L Diesel Engine (87-95)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.968
Beta Ratio: 2/20=24/44
Burst Pressure-PSI: 390
Nominal Micro Rating: 25
Gasket Diameters
Sure seems like there is more than 2 inches difference, but I replaced a Puralator standard filter with a Wix 51734, so maybe there was.
Courtesy of www.wixfilters.com
