Recently picked up a 19 passenger school bus I'm converting to an RV. I got it dumb cheap, but it definitely has some questionable history, so I'm looking to figure out what I should be doing to get it tuned up and prevent any further damage... It's a 1994 E-350 with the IDI 7.3 (non-turbo), E40D trans. about 240k miles. It's been out of bus duty for a while, used as a tailgate vehicle, then to transport people + kayaks for a short time. I wouldn't say it's been abused, but I get the impression it has not been meticulously maintained in recent years. This is my first ford, and first diesel, so I'm pretty in the dark and trying to get myself up to speed. Most of my experience comes from GM gas trucks.
What I've done so far:
1.Changed oil, it was black and gross... Used Motorcraft oil + FL-1995 filter with extra quart capacity.
2. Bought a fuel filter, haven't changed yet. it's tucked up under the dash kind of in the van configuration and I haven't wanted to mess with it yet.
3. Changed VSS in rear diff (more on that later).
4. Previous owner had all new glow plugs + 2 new batteries put in recently
5. Fuel additive and a can of seafoam (I swear by the stuff in gas engines, not sure about diesels but it shouldn't hurt)
Issues I've found so far:
1. White smoke at start up. My guess is low compression? Or is there anything else I should be checking first? Starts right up with about 1/4 throttle, need to hold that for about a minute till it warms up then it idles fine. White smoke for a couple minutes until its warm, then it runs great.
2. Hard shifts + OD light flashing. This is the one that scares me. Previous owner had it looked at by a good shop, and they were convinced it was the VSS, so I replaced that. It seemed to shift better, but its still hard, and the od light still flashed constantly. I haven't been able to pull codes yet, but I'll do that later today. I assume my Bluetooth OBDII reader with Torque should work for OBD I as well??
3. There's some kind of small cooler in front of the radiator with a bunch of fins smashed, could that be a transmission cooler? Yet to trace the lines and see if it is anything I care about.
4. Rear ABS light is on, even after replacing the VSS, could be related to #2?
So those are the big things, but what else should I start doing to make sure this thing is running well and will last for me? Basically looking for any info on where to start getting an understanding of this Vehicle. Coolant flush? God knows when that was last done.. Air filter? Haven't even found that yet, but it's probably dirty.
EDIT: Also, what are the options for putting a turbo in. I don't need a ton of power, but I do plan on using this at elevation, and I get the feeling she won't be happy with that without some boost..
Thanks in advance!
Thanks in advance!
