HammerDown
Does the below fitting coming out of the filter head (arrow) have a O-Ring in it...If so who carries it? It was damp w/fuel and I think this is where it's sucking air. I did get about 1/2 turn out of it...felt like it was tightening against rubber.
Looking down at the IP, on the right side there is a little well that is holding fuel (follow pencil). Where on or in the IP would cause this leak?
Below I used a shop towel to clean up the fuel (very little)...again where would the IP be leaking from?
Is there a replacement for this type of battery terminal? (starting to split at arrow)
