Feeler for a 5 speed 4x4 conversion kit
CountryBoy81
Mtn. Grove, MO USA
I got ahold of him and he said he would def like to have it, but he is still in the northeast working this storm. I will let you know as soon as I get a solid answer. Thanks
jaluhn83
Upper Marlboro, MD
You need the floor pan cover piece too, the automatic has a different shape and woln't clear.
It's a worthwhile swap for sure, and the price is fairly reasonable. Good luck!
jaluhn83
Upper Marlboro, MD
Hmm, well maybe I'm wrong. On the older trucks you do have to change the pan. (just the removable part around the shifter though, not the whole cab floor) The C6 pan is essentially flat while the ZF has about a 1" raised area. Maybe the E4OD also uses that raised floor pan....
MadScientist
