Brianedwardss
You guys that are "pinning" the clutch what exactly are you doing??
I just drilled a 3/8" hole in the meaty portion of the clutch, spun the fan til one of the internal clutch disk/puck was covering my new hole, then drilled a 5/16" hole in the puck. Then I filled it with a wire-feed weld from both sides. Maybe took a half hour.
I've never had a 6.9l get very warm, but 7.3l's seem to like it Hot! Today it was 16 degrees where I went hiking, and on the drive up there even with my locked fan, new radiator, newer water pump my truck was reading 202 the whole way.
