SKimballC
I was digging through the archives doing some research and found this thread-
http://www.oilburners.net/forums/showthread.php?t=5760&highlight=wastegate
I have a factory turbo I will hopefully be installing after a little, ahem, making things right- see my other thread- and since its off I figured I could check out the wastegate situation. It has a locknut on it and maybe 3/4 an inch of threads left. I pulled the rod off the wastegate but if I shorten it any more it won't reach to fit back on. The wastgate lever is at the end of its travel with the rod where it is. Does this mean that the wastegate is already maxed out?
As for the pyro, I will need to tap the exhaust somewhere for a probe. I can easily do it now with it all off. My current probe will reach the upper portion of the up-pipe, but I was considering putting it lower in that pipe or maybe even in the y-pipe. I keep hearing that lengthening the wires on a pyro affects its accuracy, so will an extra 18" be a big deal?
But back to the archives. Its such a good resource and easy to use. In a couple more years its gonna be a beautiful thing.
Unlike a certain other forum that shall go unnamed with its worthless search engine.
