junk
As part of my engine swap I'm enlarging the turbo outlet to use a 3" band clamp versus the 2.5" or so that's on it now. I didn't really hit 3" the whole way as I do have a 1" piece of 2.75" ID tubing to close the gap. I know there are some gaps in the pictures because I get excited and forget to take pictures. I don't have my exhaust system and down pipe yet, but once I get that I'll show how I modify the 95-97 power stroke down pipe to work with this. This LINK has more pictures.
Here you can see the difference between the factory clamp flange area and the 3" clamp flange. This is after I cut the factory flange off the elbow. Factory on the right.
Here is the fixture I made to hold the elbow for welding. This is before I welded the fixture.
Here is the fixture I made that bolts into my power hacksaw to cut off the factory clamp flange and about 1" of the elbow that gets necked down. The 5/16" bolts are recessed into the plate to allow it to bolt flat into the saw. A 1/2" bolt worked great for holding it in to the t-slot.
Here is the factory elbow sitting in my saw when I was figuring out the fixture.
