Facet Gold Flo thoughts
Kevin 007
Full-floater
Nelson BC Canada
Facet Gold Flo fuel pump thoughts
Does anyone have a Facet Gold Flo or Interrupter electric fuel pump in service on their idi? I recently acquired another idi, 88 F350 CCLB 2WD. with a Gold Flo mounted on the frame rail, after the FSV. Seems to be working fine. Any thoughts on these or where they should be mounted? Its supposed to have 12''-24'' of dry lift, 2.5-8 psi, 74 micron filter and 32 GPH of flow.
Im normally a mechanical lift pump guy so im out of the loop when it comes to electrics. I will be leaving it for now as its running fine, but just curious if I'll have to upgrade to a duralift or relocate to a higher position. I would like it in the engine compartment.
Sorry, no pics just yet.
CDX825
filtration nut
Litchfield,Ohio
Ive looked at the other facet pumps beside the dura lift and wondered how well they would work.
Waystro
No Class
South Texas
85 in sig is running one seems to do its job if I have to replace it I'll be getting another
Mine is mounted next to the starter relay in fender.
Greg5OH
MI
yes from what i gathered about the facets they are puller pumps. mounted on top of the ****** unit on a trailer/straight truck and pullign fuel from the under bed tank.
mine pulled the fuel abotu 1' high and 16 feet from the back tank no problem in a dry unprimed system.
tke395
