jimraelee
I've noticed for a while now that after a week of sitting the 91 F350 7.3l turbo auto trans ( not sure if anyone needed that info, but to save the questions) will be a little hard to start... I've had a badly corroded pass side positive cable for some time. Today I finally made the priority to change it and give the starting system a good once over to make sure its ready for January's cold temp. When I had both battery positive and negatives off I decided to try a trick an old guy showed me. I hooked up the positives to each battery, then took a test light and inserted in series with the negative terminal and battery cable. Nice glow of the test light. The old guy told me that you will have minimal drain on a battery, especially with new cars and all the electronics on board. I remember seeing a dimm glow. Well on this older non elec truck I shouldn't see much glow. But I do. Next I hook up a DVOM in series the same as the light, leads connected to the amp setting, and also set the DVOM to DC Amps. I get zero, or 0.005a However when I check my 94 Nissan Sentra, I get no light and 0.0a on the gauge.
Question the glow on the light is not good correct??? and Why is he DVOM not showing anything. On on the Sentra, when I had the test light hooked in series with the neg terminal, when i open the door or turn on head lights, I get good glow on the test light, just as the truck just sitting.
mind you I have checked, or unplugged all the usual culprits, ie headlight switch, pulled all fuses under dash, pulled the plug under hood for the GP controller, no change in light. The only time the light goes out is when the Fuse links connected to the relay next to the pass side battery is removed from the circuit.
any thoughts????
any thoughts????
