Mikes91
I want to add a fuse box for aftermarket accessories to my truck.
I'll need certain items to be on at certain times... my guess:
- Holley Red pump on at key "Start" position and above
- CB on at "ACC" position and above
- Gauges on if parking lights or headlights are on
Awhile back, I think I saw a post that listed an aftermarket fusebox that would handle this. My computer got a nasty virus sometime after I saved the link... and I forgot to back up my Favorites before reformatting.
At any rate... I don't want to add items to the under-dash fuse box UNLESS it will accommodate more items and I can tie add-ons into the circuits mentioned above. Was wondering if anyone knows of an aftermarket fuse box I could add under the hood to handle these items. I'm worried that hooking into the ignition and headlight system will be a bear... hopefully there's a way to do that which is not shabby.
Also... anyone know of an easy way to hook up multiple items to a common ground? I have 4 items held down against the metal under my dash with a bolt... looking for a better way to give my components ground.
Thank you,
Mike
Thank you,
Mike
