When I bought my Truck in early November it came with Mr. Gasket green and the truck would have starting issue, White Smoke issue, and quite running a lot. I am new to Diesel but I bought a Carter 110 gph 8-16 psi kit it came with five wire relay and fuel Pressure regulator for $120. I started with the regulator set at 7 psi and have rolled it down 5 psi because at seven it would vapor lock the tank because the amount of fuel it was moving. The truck runs great, put over 4,000 on her now. It is a daily driver now but needs a valve job. Good thing is I have another truck to drive while I pull the heads. I would not run the Mr. Gasket sump pumps because of white smoke, no start, and are only used for transferring fuel from one tank to another, it state that on the package. You need to buy a Fuel Pump like the other members are telling you. don't go Green or Red unless you like problems. Good luck on your choices.
