EGT's out of control
EMD_DRIVER
Say what?!?!
Beaufort, SC
If you are going to change the Y pipe to plenum hoses, I would recommend also changing the turbo outlet to Y pipe O ring.. Here's the part numbers for them: Turbo Y-Pipe O-Ring: Ford: F4TZ-9E436-A International: 1818372C1 It's only available from these two sources, that I've found...
HERE is the kit that I put on my 97. It has the updates CCV and CCV to turbo hose.
Here are the Y pipe to plenum boots I used..
