Okay guys, I was just having a discussion with a friend of mine who is trying to work out a gearing problem on his truck. He is currently stuck with really low (like 6.52 ratio) gears and it's not easy to change them out (its not a pick-up truck). That lead us to the more fundamental conversation of what is the actual physical parameter that limits diesel engine RPM. An extra 500 rpm in his case would give him as much benefit as a regear and depending on whats involved to get there (motor work, pump work, etc.) it may be way more cost effective. I know our trucks by diesel standards rev fairly high when compared to something agricultural or a _ummins. Is it a rotating mass issue? A balance issue? A pump issue? Is it that the power curve falls off so why bother? Fuel consumption gets stupid? Reliablity goes way down? Valve train limitation? I'm sure there are plenty of high performance applications that rev out way farther than a stock application but they are probably only expected to survive a short time.
What is the trade space?
I know the answer may be different depending on the application but I'm thinking in general. There are probably some guys with F-Superduties that would kill for 5 more MPH sometimes.
Just thought I would toss this out there to start a conversation and maybe learn something.
Thanks!
Thanks!
