Decisions, decisions...
NCheek
Howdy
College Station, TX
Somewhere in the near future I'm going to be acquiring a DNe2 Overdrive. Upon installation into my truck, I have the option of mounting it on the back of my T-19 with the 4:1 1st gear, or mounting it onto a T-18 with the 6.32:1 1st gear.
I like the idea of having the lower 1st gear for launching with 3.55 gears, but I am worried about daily driveability with the wider spread. I just don't want to have to redline to keep from lugging the next gear.
What say you, IDI gods?
FordGuy100
Silverton, OR
Whats the 2nd gear ratio in the T-18? I launch in 2nd gear with my T-19, all I have to do is rev it up a bit and slip the clutch, even with my 3.54's (2nd gear maxes out at 35mph). But the T-18 is a non synchro'ed 1st gear, and that might be a pain in the **** sometimes (will grind trying to go into 1st sometimes, stuff like that).
NCheek
Howdy
College Station, TX
T-19 - 4.02, 2.41, 1.41, 1.00
T-18 - 6.32, 3.09, 1.69, 1.00
I will probably end up putting the T-18 in, but I don't want to lose my custom shift knob in the process...
I would just swap the top part of the shaft, but the t-18 has a one piece shaft and the t-19 splits next to the floorboard level.
Does anyone know if the top cover of the T-18 is interchangeable with the top cover of the T-19? If nothing else, the shift lever?
As far as losing the 1st gear synchro, I don't normally downshift further than 2nd gear anyway, so it shouldn't be a problem. And with the t-18 2nd gear being lower, it will be easier to get started.
FordGuy100
Silverton, OR
That 2-3 split is pretty big on the T-18 as well, but I like the 2nd gear ratio way better, that would be a better gear for me to launch in ;Sweet
Just keep in mind Ford never put the T-18 behind a diesel. I think your first gear would be a complete waste.
NCheek
Howdy
College Station, TX
But having the optional low gear instead of switching to 4.10's is what is tempting me, because with 3.55's and any load, the 1st gear launch leaves a lot to be desired. And even if it is too deep, I could leave the box in OD or just start in second...
I believe Ford must have used 2 different 1st gear ratios in the T-19. I believe the 83-84 ones are different from the rest. My first gear in the Moose Truck is extremely effective. Maybe you just need an earlier T-19?
hesutton
The Anti-Anderson
Bowling Green, KY
With 3.55's and with 37 inch tires, I still find very little use for 1st gear other than starting from a dead stop on a hill or something. I think I could pull the house up the street with the truck in low range and 1st gear.LOL
I've never driven an IDI with a T18, but that may be overkill kind of low.
Heath
NCheek
Howdy
College Station, TX
Well, I actually have all three configurations of the Borg Warner T-18/T-19 gear sets.
The T-18 with the lowest ratios, from behind an '85 302: 6.32, 3.09, 1.69, 1
The T-19 that was behind a 460 that is now in my 82: 5.11, 3.03, 1.79, 1
The t-19 that is behind my 6.9: 4.02, 2.41, 1.41, 1
Maybe there was some difference in the transmissions that ended up behind different trucks, I haven't a clue.
NCheek
Howdy
College Station, TX
Looking in signatures, i see that Sean's DD has a NP 435 (6.69) 1st Gear and DieselJD just swapped in a T-18, didn't he?
To you guys running the lower gearsets, what do you think of them?
