OK lets review some basics here, because I'm hearing some things that need examination. First, when you install a turbo the factory CDR fittings get plugged. If you didn't do anything else, you'd have an unvented crankcase, which is majorly bad. The weak spot in a setup such as that, would be the turbo drain, and all the crankcase presure is going to head for that spot, and the dipstick. Under such circumstances, the presure would push oil and gas out of the grommit. It's not inconceivable that the restriction in oil flow might not cause oil to push out of the turbo seals and who knows where that's going to go. Now, if the install is done correctly, the CDR will be relocated and presure will vent either at a valve cover, or at the IP housing. If you want a road draft tube, the hose just vents to atmosphere. If you want a CDR, it goes to that, and then the CDR re-connects somewhere in the air intake. If there is any doubt that your crankcase is not vented properly, take your oil fill cap off and put a screen over it. This is not too dirty on a 6.9, with the oil fill off the front of the gear housing, but the 7.3's will get a lot of oil sling due to the placement of the opening. Now, the other issue with oil leaks and turbo drains, is the proper ventalation of the turkey pan. Early turkey pans that were designed for non-turbo engines, needed to have their internal baffle ventilated with an ice pick. If no holes, or not enough holes were made, you can get oil overflow from lack of draining. Replacement turkey pans are all set up for turbo's and have the proper drain built in. I would pull your turbo and do the hot oil test I mention in my turbo install article in the Tech Articles section.
