cdr delete question....
nhwrench01
new hampshire
I did search this but got no answer.. so..
Back story, 86" 6.9. bought a used turbo system, 093.. have everything but the valve covers... so no cdr on the engine..
the oil fill tube ( bolted to the injection gear cover} is a 1/4 twist on , i know i need a vent for crank case pressure..
I drilled a 1/2 hole in the side of the filler tube and welded on a short 1/2 pipe, then ran a hose from that down under the truck, just like the big rigs.. or the older ones anyway
Any one see a issue with this? other than some mist under the truck,, mostly looking for engine or running problems .. thanks
I would suggest a catch can, as there is a lot of turbulence from the IP gear, you'll lose a steady amount of oil from there, that's why people usually weld an AN fitting on the valve cover and use that for the vent.
nhwrench01
new hampshire
Thanks Nero,, didnt think of that,,, guess im doing that soon..
