I bought the truck in january of 08. It was a mess to say the least. after rewiring the back half to get tail lights, putting in a new vacuum pump, and replacing the fuel filter I drove it 120 miles home. Over the next two weeks I stripped and cleaned the interior (literally a 5 gallon bucket full of sand, dirt and dog hair ), rattle canned it black and started driving it daily.
I drove it till april and noticed it liked to get hot (this was in florida where the asphalt gets to 140+) pulled the cap and found rusty liquid. Bought flush, cap and hoses. Flushed till clear, filled with new coolant and dca4 after installing the cap and hoses. That lasted till may when the waterpump started leaking. Replaced the lower hose again (had a pinhole in it from the parts store hang up loop) the water pump and the thermostat.
about a week after this I swapped in the zf5 and installed the hypermax kit, turned the pump up two flats and put the first set of stacks on it.
Got hot once coming across montana on the way out here. flushed the cooling system and refilled again, replaced the cap and made it here.
I have been working at a dealership so I flushed it a couple times there and the time before last I installed a coolant filter. The coolant stays the correct color but I think the system has deposits in it from the PO (S) before me.
I need to pressure test it and I guess I need a new radiator.
from what I understand these things have such a big cooling system that is so efficient they rarely get even kinda hot. I think mine is pushing the limit and I hope I havent already cracked the heads.
punk
Two things come to mind, they may have been addressed and I missed it but...
I don't see anywhere that you have changed the thermostat. If someone put in an incorrect aftermarket one, that can cause a problem.
The second item is if the fan clutch has been tested or not.
For me if the engine is seeing 230+ in any area, regardless of location, it is getting hot and something needs to be addressed.
Just some thoughts...
Good thread BTW!
