Al, if you really want to get into documenting something pretty involved, how about either fabbing up or installing a front shackle reversal kit? Yeah, I know, cost would be a big factor with that.
Todd
This one, well again, you hit nail on head, cost and a few other related things, see the following as it's MORE important to me that this at this time I"m still toying with idea of a longer spring....makes my head ache doing the math!
Also, I think I noticed in another thread that you were considering doing a D60 high steer and cross over steering - just another thought and I know cost could be a factor on that too. Let see - a more "realistic" suggestion
This is a fantastic suggestion as I'm only adding in the RH knuckle Cross over HI steer ARM similar to what Dieselcrawler has. His however takes it the next step and adds in hi steer tie rod if memory serves me correct.
I'll have the HI steer arm from box to right knuckle, already have the parts, need studs for knuckle those come with parts OK'd below!!! I'll retain the stock tie rod in the stock location for now or I may get some DOM and make a custom one...not sure...for now..stock!
Wife has given OK for NEW front end parts, but may take one to two months before those parts are purchased. That will entail on my Front D60
INNER axle seals
Lunch Box locker a Spartan to be specific to brand
NEW king pins and bearings
NEW outer axle needle bearings,
NEW Pinion seal
Rear diff will be Lock Rite lunch box
NEW pinion seal
Crush sleeve eliminator kit!!! Ford 9" uses same kit!
Did you ever get your bigger fuel tank installed? The installation of that, along with making the sender work with the big tank, would be a great write-up and probably pretty useful to a lot of us on here. Todd
Rear tank is still something I'm trying to locate or purchase or fab. NOT sure which way to go. The problem with this is how I set up a rear winch be it PTO or hydralic or swap PTO to front and Electric on rear...THAT ONE SMALL DETAIL IN MY MOMENT OF NEED FOR A REAR TANK WAS FORGOTTEN ABOUT!!!!
Failing to plan is planning to fail so rear tank is sort of on hold whilst I thunk out kinks of winches etc.
Same with rebuild of PTO winch, I am waiting on a couple people to get back to me for shaft builds, before I can go much further.
I almost forgot about that rear seat lift. Still interested also.
Replacing track bar(?) Bushings for a D60.
Funny, this is maybe something going to happen when I do my 60 rebuild. It's hanging on the one 60 getting prepped for rebuild, bushings look like *****! so maybe...just maybe..
Now I have to make a damn book and write all this down...DOH!
I'll only do what I can/afford etc.
As for a dash, unless I have to remove one AGAIN my fault for not documenting that one...I won't be doing one ...but who knows, I may pop out 92 dash and install a new wire harness. gotta look at a few things I've got floating around here.
Keep em coming,
First on list is comp test though! Now that those GP's are all done and easy to get out I'll be back in there soon!
Thanks Guys!
