Changing shocks on a D50?
fields_mj
Brazil, Indiana
Anything special I should know when changing my front shocks? From the looks of it I remove the tire and rim, unbolt the shock, and bolt the new one on. Put the tire and rim back on and I'm done. Sound right?
Thanks,
Mark
dyoung14
Is getting worn out
spencer,tn
Shocks are dead easy to change, Are you sure you got a dana 50? and not a Dana 44 the look the same but you can tell them apart, if it has big lockout hubs like the dana 60 has then its a 50, but if there smaller then its a 44
dyoung14
Is getting worn out
spencer,tn
No need to take the tire off like said. Just unbolt the old one, and put the new one on.
I think its easier to take the tire off, plus you can check the ball jointa and tie rod ends(as i know thats important!) and check the brakes and things
Diesel_brad
Dunce
gilbert pa
Dave. he has a 92+. They didnt use the D44 in a F250 by that point, only D50
fields_mj
Brazil, Indiana
x2...leverage...jack the tire off the ground. grab the top and bottom and wiggle to check your ball joints. then side to side to check the tie rods.
True. I'll probably do that anyway, but I'll still take the tire off. More room for the impact in there that way :)
alienturtle
Human
Ripon, CA
indeed. make sure you put the shock going the right way as well...SOME have an UP arrow or something to that affect on them.
Diesel_brad
Dunce
gilbert pa
Yes. What alien said. Make sure the shock is in the right way. BILSTINEs go in "backwards" of they way you would typically mount a shock
